unsticking a froze block
What did you use to unfreeze the block
  • cola
    Votes: 0 0.0%
  • diesel
    Votes: 1 4.0%
  • 50/50 ATF brake fluid
    Votes: 5 20.0%
  • Kroil
    Votes: 9 36.0%
  • Marvel
    Votes: 4 16.0%
  • PB Blaster
    Votes: 1 4.0%
  • WD-40
    Votes: 1 4.0%
  • oil fuel mixture fire in cylinder low and slow
    Votes: 1 4.0%
  • Other penetrant oil
    Votes: 2 8.0%
  • Other
    Votes: 4 16.0%
  • Press, air hammer, brute force
    Votes: 3 12.0%
  • Total voters
    25
  • Poll closed .
out plowing
Having read many posts on what to use for loosening up a stuck block lets have a pole at to what you used to get yours unstuck.
Is this a trick question? :D If so, wouldn't the correct answer be 'Other'? My vote of "Other" would be to use a heater unfreeze a block. ;)
Over 50 years ago, had a Model B engine that was stored out of doors for about 12 years, & after removing the crankshaft & three (3) pistons, found one piston stuck that would not move up or down by hand.
For seven (7) days, turned engine upside down & then right side up, & every day filled the crevice between piston & cylinder with "Liquid Wrench".
On seventh day began lightly tapping piston on top with a wood 4x4 & tapping both sides of the piston's bottom with a wooden tool made with (2) shaped 2x4's with a horizontal 2x4 on top.
When the slightest movement occurred, applied more "Liquid Wrench" mixed with about (20) % motor oils.
Cylinder cleaned up with "Liquid Wrench" on wads of (0000) steel wool.
Really old, sunken marine engines have been freed by putting a load of
burning charcoal briquets in a stuck cylinder, and leaving them in place
until cool. Vacuum out the ashes.
Follow-up with MMO and tapping with a wood block and mallet.
How do you get it lit ?
