I recently bought a 1930 Murry 155C. When I was servicing it I found there is no grease fitting for the universal joint. Was this some aftermarket unit or what?
Maybe this is DUMB, but I'm going to try it! "VERMIN," my '29 coupe. It was restored in 1987, sat for many years. I'm sure the u-joint is bone dry. While the floorboards are out, I will drill a 1/8" hole in trans. rear housing, squirt at least 1/2 bottle of 600 weight into the u-joint area to create a "puddle" for the joint to dip into. I THINK that, along with the small amount of oil that gets through the trans. rear bearing will keep it lubed. I'll plug the 1/8" hole with a dab of silicone rubber. Not suggesting you try that, but Ol' Bill's gonna' do his!! I don't have much faith in filling the WHOLE u-joint area with grease, as centrifugal force just "blows" the grease away from the u-joint! Bill W.
You don't grease a model A u-joint like a modern car. There is a zerk on the side of the housing that covers the u-joint, remove a bolt for the speedo housing and fill the entire cavity with grease until it comes out the bolt hole.
Greg...When did Ford put a "zerk on the side of the housing that covers the u-joint"?
I know there is one on the A-7085 Transmission main shaft bearing retainer but on the "housing that covers the u-joint"? That would be A-4520 U-joint housing cap--outer assembly and there was no zerk on those parts that I know of.
Of coarce A-7085 would be considered part of the housing I guess.
(I think that is what you meant to say)????
Pluck
Steve,Surly you are joking with usAt least I hope so.
Pluck
Tom,I've never seen a bearing retainer without the threaded hole for the grease zerk. Have you used a mirror or carefully felt all around the rear bearing retainer for the zerk, or the bump where the zerk fits.
Bill, I wouldn't drill a hole. For one thing it will put metal filings in the housing. If you pump in grease the U-joint will probably outlive most of us. Mystik JT-6 high temp is a very sticky grease, and I'd have no fear of it not giving the U-joint plenty of lubrication. Also if you don't have a sealed rear bearing some gear oil should find it's way back to the U-joint.
Are we brothers? God! I was looking at housing pic & said to myself, "Self, your a dodo, you can pump the 600 weight through the dumb grease fitting!" Oil in the bell was to be a 1 shot deal. Car done in 1987, no written history, everything was empty except the engine oil, (very clean). Oiled trans & diff, changed motor oil, fired off like a click from a Bic! Drove it maybe 2 miles in the neighborhood, bad oil leak from missing lower timing gear bolt. Ripped everything external from engine to re-seal & regasket and modern head gasket. Engine rebuilt by reputable local rebuilder in '87, (his brass tag riveted on R/H side of block)Bill, If you want 600 gear oil in the housing just fill the tool kit grease gun with the heavy gear oil and pump it in the original fitting.
