I rebuilt a universal joint that I purchased through ebay using a kit from Brattons (cross, bushings, and clips). The rebuilt joint has about 1/8 to 1/4 inch of play across each yoke. Is this normal? When I bolted it to the transmission drive, put on the rear cap, and rotated the joint, I noticed a sound like metal rubbing on metal. I assume its the joint rubbing against the inside of the cap. Will this go away once the engine/transmission is hooked up to the drive shaft/torque tube putting the drive train in alignment?
