Hi,
I'm getting their it's just a slow process!!!!!!
I have my differential / torque tube assembly out of car and inspected the universal joint. Seems to be no rotational wear at all. My concern is the end to end along pin movement (about 1/4 inch from stop to stop. I also observed that the universal has been rubbing the universal joint inner cover on the inside. Not bad but observable. In theory this should not be able to happen but it has or should I not be concerned about a little rubbing?
No discernable play in the transmission rear bearing and maybe .020 " in the drive shaft bearing. Replaced drive shaft bearing and now no movement. Is the 1/4 " stop to stop normal or should I replace the universal? the UJ is the kind with the snap rings.
Thanks in advance for all help concerning this issue. Jim
