Bob from Northport Well-known member Mar 11, 2016 #1 On a 1927 Model T Huckster, how is the universal joint held in?? After the engine is pulled, is there a bolt or a way to removed the U-joint?? Thanks!!
redmodelt Well-known member Mar 12, 2016 #2 There are two plugs on the drive shaft tube (top and bottom) just behind the bell. The U-joint is held on with a rivet (or should be) which is driven out when lined up with the two holes.
T tmodelman Well-known member Mar 12, 2016 #3 Here's some photos of those steps to remove the U-Joint Attachments 4th main.jpg 41.4 KB · Views: 15 IMG_7959 (550x413).jpg 142.3 KB · Views: 18 IMG_8130 (600x450).jpg 152.5 KB · Views: 16
