Universal Joint Lubrication
What about the grease used in modern front wheel drive constant velocity (CV) joints? This stuff also has to stay in circulation and not "wagon track", as was described. It does a good job of keeping the joint lubed for life unless a boot tears. I've bought some to try but it's still on the bench!
John Deere Corn Head Grease is just such a grease used in CV joints. Here's a great video about it. https://www.youtube.com/watch?v=UEwk_sYP6A8 Glad I just bought it and put it in.
Very interesting video!!! Looks like if one doesn't have a John Deere dealer nearby, a trip to the local auto parts store for some CV grease will do it.
I liked that video. I can buy JD Corn Head grease in regular/standard size grease gun tubes at several dealers near me....course I live in the middle of farm country where we have lots of 'Corn Heads' that need greasing :D. I'm planning to use CH grease in steering boxes, universal joints (both open and closed), tie rod ends, king pins, water pumps, etc., but will NOT use it in early Ford rear wheel bearings. Heck, I may even shoot some in the crank case w/o doing any research to determine if it's good or bad ;) ;) but please don't tell G.M. about that ;) :D
I ordered 2 tubes of JD cornhead on Friday, got it today and put it in minutes ago. I took off the speedo gear just to check it, and see what it looks like, the gear would barely turn, was almost frozen up, cleaned it real good, spins freely, reinstalled, actually put in 1 full tube of cornhead grease, plus about 10 pumps of another tube till it starting coming out, needless to say the U joint was dry, thanks for the info on proper grease!
If I just add John Deere cornhead grease to the universal joint in my V8 will it mix with the other grease, and if I remove most of the oil out of the steering box will cornhead grease mix with the remaining oil?
