Ultra Sonic Cleaners
Best to get a high-powered transducer & driver board. Then bolt and seal the transducer to your own decent-sized SS mixing bowl that'll submerge a big 4bbl. I got the 60 watt kit. Bolt is 10mmx1mm about 13mm long.
557714
Jack, Sounds great. Can you post photos of your finished product?
557714
The one I bought both heats the fluid and also does the electrostatic cleaning. It works the best when the fluid is nice and hot.
My brother found an "ole" racers trick of diluted lemon juice concentrate with water in a crock pot!!! Works like a champ!!! there is a learning curve of mix and time soaking AND the warning of do it in a WELL ventilated area!!!!
As an example, sort of crusty moped carb for about 20 to 25 minutes in about a 60/40 ratio of lemon juice to water once the crock got good and warm!!!! AND be sure and rinse clean once done...Really well!!!!
