U-Joint Torque
Anyone have the torque on the U-Joint to Transmission Shaft bolt?
Yes, put the ****** in high gear and tighten the bolt. When it feels tight that's the correct torque. Make sure the offset in the special washer fits into the groove of the spline.
Actually, if you feel the need to use a torque wrench, I'd say about 35 lbs. would be fine.
