harleytoprock
As Mitch stated, have you tried to slide the u-joint on the drive shaft splines? Try all 6 positions.
The snap ring grove is 2 1/8" from the end of the drive shaft. If you cannot see the grove you have a problem, if your drive gear is on backward it will not go all the way on.
I'm getting the feeling the speedo gear is backwards and the clip is missing.
I have a trans ready to go back in,from the end of the u joint to the bell is approx.15/16 of an inch,your u joint appears to be sticking out to far,drive shaft bottoming out,something not right in the trans,most likely.
