Should line up with a grease nipple [zerk] on the outer clam. Some have one on each. Would put it at the top IF you can get to it. Coat a bit of grease between inner and outer when assembling and coat the uni in semi fluid grease too. I would use some good sealant along with the gaskets, once the oil from the trans starts making is way back there it will leak if everything is not perfectly flat.
