I had one and found they don’t articulate as well as an original u joint. The V8 era originally had this needle design, they started with the Lincoln’s. Those drivelines are much longer than an A. When the suspension is unloaded in normal road travel, the could bind in the shorter A driveline. I sent mine back, and have used NOS ever since without worry.
Put a drake needle bearing u joint next to an original A style and you’ll see what im talking about. Originals allow greater angles than the drake.
The drake u joints are nice. They just need the longer driveline.
