The two tooth Gemmer steering sector was used interchangeably from Feb. 1929 along with the 7 tooth sector to the end of 1929. It was 1 inch shorter than the 30-31 steering column. For 1929, the steering shaft for the two tooth Gemmer sector was 43" long. the 30-31 steering was 44" long.
So yes, the two tooth sector can be used without modification if it is the shorter 29 version.
