1946
I have an option of fitting either a two or seven tooth steering box to a speedster I am building. The two tooth is in need of repair, ie the bearings that is , sector and steering rod bushes need replacing. The seven tooth also needs a repair kit. Both these are RHD steering.
Not wishing to start another long winded and eternal discussion such as the oil debate, but, which would be the better system two or seven or put another way seven or two.
Many thanks from the land down under.
