Minn-Tex Lee
Well after 4 years I am only two parts short of trying to start her up.
1) What keeps the fuel lines from leaking? there does not appear to be any "upset" on the lines as there is on the hydrolic lines on the brakes.
2) Since I am going 12 volts I bought a coil advertised as 12 volt. When
it came it said "12 volt -use ony with external resister". I thought the resister was used to convert while using the 6 volt coil. What am I missing?
Thanks Lee
Thanks Lee
