There are thousands of 2 piece valves out there you will be fine.
R
I guess my point is if you are spending money for new valves. I would not buy two-piece valves. Just my opinion.
I have seen similar damage from forged, one piece valves. I would not hesitate to use 2 piece valves. An investigation into the cause of that failure will need to be conducted.
Failure at the "weld". Believe me, this is not the first, just the only one I had photos of. If it survives the warranty period, oh well, sorry for your luck.
Caterpillar is very close-to-the-vest about their factory problems. I guess if I sold a jillion parts, and had a 1% or 2% failure rate I wouldn't advertise it either.
They re-designed both the material and the manufacturing process for new exhaust valves. I had a factory tech I have a good relationship with tell me "off the record" not to order or install any heads or valves carrying certain part numbers. We pulled our cylinder head inventory and R&R'd any suspect valves. So far, no issues with the new parts.
That failure took out a power pack (head, piston, rod, and cylinder assembly), a turbocharger, 200 gallons of coolant and about 120 gallons of oil. No, it wasn't cheap, plus our down-time.
My other baby, a 351C, is noted for this failure. I don't think anyone would rebuild that engine with two-piece valves (nor would most builders recommend it).
