criswellnk
Have there been any articles, or anything written about the rebuilding/restoration of the components for the early two-piece cross shaft brake system?
Before starting to work on this part of the project I would just like to know if there is anything that someone may have written to reference? If I don't have to re-invent the wheel from scratch, that would be helpful.
My biggest concerns are the actual cross shafts themselves and the "dogbone" (sorry, I don't remember the correct name or part number right now) that fits between them. The cross shafts have the wear points from the mounting brackets for the frame rails (build-up through welding and dress down). The sockets where the "dogbone" fits in are oblonged and worn well out-of-round. I have a couple of ideas on how to fix this point, but would like to know what others may have done, and how their results were.
The "dogbone" itself, everyone that have come across seems to be worse, or just as bad as the last one that I have found. Does anyone have a good set of dimensions to start from, or should I just get the print and start from there?
Also, the ball on the end of the cross shaft that fits into the socket on the U-joint housing, of the ones that I have none of them seem to be truly worn. Are there any concerns to be aware of with these (needing new springs not withstanding)?
Thanks for your time and help, and any ideas.
