Two Light Wire Pigtail
cfordman
Does anyone know where I can find the three contact male connector to hook up a headlight? This is the end on the wiring harness. Got rid of my Dietz halogen lights and put back what Henry wanted.
Snyder's: A-14584-B1929-31$1.65 / pr
  • HEADLIGHTCONNECTION-11170.pdf
brattons 20550 has the bullet ends which is what you need....
along with the connectors Carl posted....
Jw hash "Bratton`s has them part # 20421 you solder them on the end of the wire."
I agree. I used the bullets until I found these. Bullets are taller in the separator blocks than the brass terminals.
The bullets distort the springs in the socket and can cause shorting.
However, the bullet tips can be filed or ground down to accomplish about the same thing.
JMHO.
