twin carbs
Speedway is one source. Also Ken CT on this forum might have components. I had the best results running them in tandem with straight linkage. I could not get a pair of 94s to run well progressively. I was not able to get the secondary to seal well when closed.
Yes the link is adjustable. Set the throttle arms leaning forward at 45°. Sync the carbs at idle with out the link connected. Then adjust the link to match the position of the arms. You should be good to go.
I have used a lot of linkage and I would think Speedways set up is about as good as they come for moderate priced parts.
I made my from brass rod and aluminum....takes time but not that hard. And you can be creative.
Thanks Baseman that's a nice set up I might have to do it Rodgers way for the sake of time ,Look me up when you come to Orklend
