Turn Signals
bobmc
While going through the remaining boxes of parts that came with the car, i discovered and signal stat 900 sigflare switch still in the original box. Only thing missing is the instructions!
There are 8 wires coming from the switch. 4 of which are solid and 4 that are solid with a colored trace marking. This is a sticker on the switch that says 6volt
I purchased 4 bumper mounted lights from snyders and planned to run the turn signals completely indendent from the lights on the car. Can anyone tell me how to wire this? Car is original, 6volt positive ground.
thanks for your response
I went through this same thing under the same circumstances about a year ago. Signal Stat was bought out by somebody, but I was able to trace down instructions through Google. I think if you do an advanced search here you may come up with an earlier and better answer than mine, though.
