cederholm
In need all the help I can get on the mean streets of NYC - luckily the horn works
The PO started to install a turn signal system. He mounted two small lights under the rear frame and one of those bolt-on stalks to the steering column.
I'm pretty good with wiring but I thought I'd reach out just in case. The car has been converted to a 6v pos ground alternator.
So,
1) I will need to check if the signal stock has a self grounding case (is which I will need to isolate it) but assuming it doesn't - does the switch care about the current flow? Likewise the bulbs?
2) Should I assume that the lights he added are 12v and change them?
3) what are the thoughts for the front? Converting the parking light within the headlight housing? Getting some small for or cowl lights? or small add on lights somewhere else?
All thoughts (and pictures!!!!) welcome.
Thanks,
Carl
So,
Thanks,
Carl
