Turn signal too slow
170bdlx
Installed T/S from my 52 GMC. 6 volt, Pos. G, 7 wire, 3 prong flasher. My "A" has 2 LED tail lights, 2 film bulbs in the cowl and a buzzer attached at the flasher. I have tried 2 different flashers. The first wouldn't flash the green indicator light but one time. The second now flashes the green light.
How can I slow the speed?
Try changing the LED's to regular bulbs to check it out.If they work normally then you have found the problem.LED's don't draw enough to cycle a conventional flasher.Some folks wire in a hidden bulb to create the draw needed.There is a flasher made that works on time,not heat from the draw,but I don't know who makes it.
Probably going to have to hunt down a 6v flasher specifically for LED's, as they (LED) don't draw enough "resistance and/or amps" (somebody will correct me) to make the flasher work correctly.
You might try hooking another light into the system and see if it helps
