I have a 1950 f1, 12volt. gonna need to upgrade the turn signal switch. Anyone have any recommended switches ? or , which ones i should stay away from ?
Marko
Cannot tell where you are located, but here we buy them at the swapmeet for $20.00
Small, chrome new from china. Or used old ones for $5. or $10.
Get a 7 wire, easiest to install. Check Amazon dot com.
Good luck
Bruce
If you are considering LED bulbs, there are signal units that can handle the low current without resistors. Otherwise, Signal Stats are common and reliable. As indicated, a 7 wire allows you to go dual filament on the bulbs.
