bosborn38pu
I know there are many good options, but after searching the Ford Barn, I decided to go with http://www.turnswitch.com/Turnsignal.htm. After some initial apprehension about having to run additional wiring, I found the result well worth the effort. I used the toggle switch option and mounted it under the dash - accessible and barely shows. I mounted the control module on the firewall well out of direct view. Everything works quite well and can be removed should I wish to return to the original configuration. An advantage was that I installed the system prior to re-assembly of the front fenders - made access to wiring much easier.
