Turn Signal Lever 1929 Model A
Canton_Model_A's
Guys/Gals:
Just got my turn-signal lever from Snyder's. I have a couple of questions.
1. Has anyone ordered this from Snyder's?
2. I believe I am still Positive Ground, I have not verified this as of yet. How do you hook this up with Positive Ground
3. I have LED turn signals on all 4 corners. Is this thing just "Plug-n-Pray"?
Any help or if anyone has done this, please let me know.
Thanks!
I have not ordered the turn signal switch from Snyder's, but the instructions on their site say that the flasher does not come with the switch. There is a good reason for this. The correct flasher depends on positive or negative ground, 12 volt or 6 volt, incandescent bulbs or LED's. If you search on Snyder's site you will find the different flashers. First determine what electrical system you have (12 or 6 volt, positive or negative ground) then order the correct flasher. The switch doesn't care except the indicator bulb is 12 volt. You will need to order the 6 volt bulb if your system is 6 volt.
