Lance Workman
Hello
Recently I obtained a 1930 Ford Model A roadster deluxe. I hardly know anything about the Model As. I quickly realized I needed to add turn signals to it. Based on the positive comments from this forum, I ordered
a hidden turn signal kit from Electro-Tech. I have the turn signal switch and the control box mounted. Now I need to connect the red power wire
for the control box to a power source. The instruction manual reads "connect red wire to full time power at the ignition switch, headlight switch, ammeter or fuse block." Do any of you have any suggestion or opinions about which would be the best location. I'm really at a loss about this, but have located the headlight switch at the bottom of the steering wheel column under the hood. Thanks in advance for any help!
Lance
Lance
