Automotive Stud
I have a turn signal switch that I believe is from an F100 but it may be from a passenger car. I can't seem to find a wiring diagram for it, it is six wire and three of the wires look green to me.
I hooked it up the best I could via process of elimination. Brake lights work fine and the left turn signal works fine. When I put the right turn signal on the right rear does not flash. If my foot is on the brake I lose both brake lights when the right signal is on. Do I still have a wire crossed? Is there a way to test the switch with a meter to see which wire is which?
Thanks!
Thanks!
