loowiloowi
HI All,
I am having and have had an issue with my 30 Tudor turn signals. The Tudor is equipped with a wiring harness that is pre-wired for turn signals. the issue that I have is that the Signal-Stat 9000 control switch indicators work once or twice before the flasher stops sending a signal to the blue wire for the indicator light. All the turn signal lights continue to work but the indicator stops working.
All of the grounds are good, and I have tried a jumper ground to the indicator bulb socket. Has anyone else had this problem? If so did you find a solution or cause?
