Turn signal buzzer
Bill S
Went to Radio Shack to get a buzzer for my turn signals. They had 70,80, and 90db. What are you guys using if you have buzzers on your turn signals?
Thanks
I got the quietest ones and still had to put tape over them to soften their volume even more. They are very annoying but necessary.:(
Like a fellow forum person said, tired of wife's elbow in my side when I forget to turn the direction off. I also installed a radio shack 70db buzzer under dash and found it VERY annoying ! I tried tape, foam and was still annoyed. Next try was long temporary leads and putting in my trunk - that was good but didn't want lots of wiring. My real problem is the flasher light is out-of-sight under the dash edge and the flasher unit is under dash on passenger side and I can't hear it ticking .... so I'll try moving the flasher unit to my side next to the steering wheel.
Option: If you are converted to 12v, obtain a quiet ticker from a used modern car.
Instead of a buzzer you could mount a single LED bulb on the column or wherever by making your own stainless mount, if you would not want to drill a hole in the dash.
When it's loud you don't run around with the turn signals on you tend to shut them off as soon as you turn. G.M.
I guess I grew up (and am not that old) in the day before key buzzers,light buzzers, etc...when many of the vehicles my dad had, were outfitted with signal stat add on blinkers.
I recall the first time I left the signal running, he just sat there till we got out of the truck.
As soon as I pulled the keys out of the switch, he asked me "are you going to shut the signal off"?
I said, "oh, I forgot"
He then said "you remembered to take the keys out of the ignition, why can't you remember to shut the signal off?...you use the signal more than you do the keys".
Anyways, maybe some add on sensors for detecting upcoming turns may be in order, just a little dash board flash, etc...to let you know when it's time to turn them on;)
Lighten up, all done tongue in cheek!
Ive notice that on modern American cars they have a soft bell- like tone when the door is open....Ive thought about using one of these as an audible alarm in conjunction with my indicators.
All if not most of the tones heard on modern cars are computer generated. I don't think there is a soft bell type unit you can just screw in and put 12V to. Even the click you hear when indicating, is a computer generated tone, rather than a flasher unit clicking.
I put two buzzers on my coupe (bcause of the way the lights are wired) and one on my roadster. They make me jump the first time I use them after a while, but I no longer leave the indicators on by accident, and turn them off as soon as possible. I toned them down by wrapping them in tape.
Mart.
I did the same as Mart. I got the flasher from Ron Francis Wire Works and was unhappy with the loud sound, but by wrapping tape around it a couple of times, it toned down enough to be bearable.
Some cars have the bell sound go on when the signal lights have been on a longish time. My wife's Ford 500 does this.
Mart you didn't need two buzzers. Use two diodes from the buzzer to prevent the left side or right side from operating both sides. G.M.
