Tudor Front Door Garnish Moldings?
Am doing a '29 Tudor. Got it in pieces. Found the center back window garnish molding, as well as the two rear side window moldings, both the part that goes around the side and top of the windows as well as the piece that goes along the bottom of the window when it is closed. Could only find the lower moldings for the two doors, I.E. the part that you grasp to pull the door closed. Am starting to wonder, was there a frame around the sides and top of the door windows like is on the rear windows, or is it just the upuholstered strips around the doors? Can't find them in the catalogs, so not sure about it.
Thanks for input,
Ron
Thanks for input,
Ron
There are no "frames" or "garnish mouldings" around the sides and top of the door windows on the Tudor Sedan. That is why they are not listed in a catalog!
Pluck
