TuDoor problem
MikeMort
Hi,
Body is off the frame on the 1930 Tudor that I am restoring, and I notice that the door in passenger side is not closing as it should. The top of the door above the window makes nice contact with the body,but at the bottom there is a gap of about an inch. Door is not sagging as the door lock lines up fine. Now what can I do about it? thanks
Chances are you will have to adjust it when you put the boby back on and the wood kit is being properly fit. Rod
Don't worry. Nothing will seem to fit until you get the body on the frame, get the wooden blocks in between the body and the frame and start tightening bolts and putting in the rubber shims. Sometimes it seems like you'll never get it right, other times everything seems to fit right off. Hope yours is one of the latter!
