Bruce/Guys, thanks for the feedback. I've been toying with the idea for 16" rims with radials, but wanted to be sure I could run them tubeless. Now the search is on for four 16" rims. I did see a really nice set of 15" rims for a 33-66 Mopar that has the same bolt pattern. I have to check and see if they will work on Model A brake drums.
I must start by saying I don't know the answer to your question but be sure to check for the fact that Model A (and all the way to 1935) Ford brake drums are at two levels. If the Mopar wheels are designed for a flat drum you may have a very dangerous situation. The raised area on the Model A brake drum will keep them from seating and tightening the nuts will put too much stress on the lug nut holes leading to possible failure (the wheel falls off). You may have to make adapters to solve this problem.Bruce/Guys, thanks for the feedback. I've been toying with the idea for 16" rims with radials, but wanted to be sure I could run them tubeless. Now the search is on for four 16" rims. I did see a really nice set of 15" rims for a 33-66 Mopar that has the same bolt pattern. I have to check and see if they will work on Model A brake drums.
