Jwawhite
Question about the steering wheel to start. Is the steering wheel mount nut flush with the steering rod threads?
My steering wheel and Tube Assy are about a 1/4 inch or more apart. If I loosen the Tube Assy at the steering box -clamp- and loosen the bracket at the dash, it seems I can close (raise upwards) the aforementioned gap. But I haven't removed the Cover at the dash which shows the gear bar through the window on it. My concern is if I raise the Tube Assy upwards, won't the gear bar rub up against the backside of the gear indicator window? Is there also an adj on the gear bar? Second photo is illustrative only showing cover on dash over gear orange colored bar
