37 Coupe
I hope someone can help me or give me pointers on this problem I ran into today.Trying to put the soft top into car that came with it. It is a '57 top but I was under the impression it will fit as is. The two swing arm"feet" will not align with the four studs in place on floor. Slots in feet are off about 1/2". Were the four stud placements different on '55 than '57? Is it a tight fit and do you need springs removed to lessen tension so feet will move somewhat? One spring was off when I got it but I placed it back on on the bench,real ***** to attach.What am I missing? I thought it would just drop on the studs.?Thanks fo any ideas.
