I have repaired badly damaged and rusted trunk hinge support areas on my 1930 coupe. I am getting ready to install hinges and would like to ask someone for the size of the gap between the top of the trunk and the body. I am not concerned about the sides or bottom gaps because I will be rebuilding those areas and can adjust as I proceed.
So if you have a well fitting trunk lid on your coupe and can give me the top gap size when the trunk is closed I would very much appreciate it.
Thank you,
Tony
Thank you,
Tony
