bill41ford
Just installed a modified crank mount fan pulley on my 8ba in my 41 coupe. Got suggestions on this forum that got me to this point concerning the mods to get this done. Everything is lined up with pulleys but when I ran the engine the pulley (that was removed and turned around and rewelded) does not run completely true. I tried to get it straight on shaft before I welded it but evidently it wasn't exactly correct. I am getting a slight wobble from the pulley. nothing radical, belt tracks ok, but not totally smooth as I would like it. Not quite sure if I need to take it off and reweld or some other way without getting that carried away. Don't have lathe or balancing machine. Any ideas?
