Cool Hand Lurker
I was all set to go to the MAFCI Tour in Rapid City when my 1926 Roadster started running like a clothes dryer tumbling one boot. It was only running on two cylinders. When I bought it the last owner had installed a True Fire electronic ignition system in the car and it has worked well up until now. I don't have the original parts so I will attempt to fix this system before going out and buying the original coil boxes and distributor system.
I put the True Fire on the bench and hooked up all the wires in the right places, both to the terminals on the box and to the terminals on the commutator. I first took the connector plug out of the coil and tested it separately. The coil checked out OK on all four high voltage terminals then, but when I reconnected the plug only #1 & 4 would spark. Nothing on #2 & 3. The buzzer worked with all four terminals however. All of this was with the rotor NOT INSTALLED but it still sparked on #1 & 4. Putting the rotor in its place and rotating it so the magnets passed by the sensors did nothing.
You don't need to tell me how wonderful the Henry Ford system worked for 84 years, that is not the question. Instead, are there any ideas as to what is wrong with the True Fire?
