jim t utah
trying to find a supplier of true 600w oil also known as steam cylinder oil for rear axle and trans. i don't want any of the new formulated lower viscosity oils 2270 . thanx
Many treat this 600W lube like its a sacred fluid.
WHERE is it noted as to be used in the Model A ******, rear end, or steering in the Instruction Book or other period pieces?
I have found it, I think in one place in a Service Bulletin.
I use the mixture the vendors sell, and it seems to work.
Is there a frequency of bearing problems among those using different lubes?
Thanks for your help.
Mobilgear 636
BP Energol GR-XP 680
Castrol Alpha LS680
Shell Omala 680
Texaco Meropa 680
How do you know 600W was 375? I have been using texaco 650T 1000. Never had a problem but it's too thick for winter in the north east. My next pail will be 680
Why do some folks want to waste engine power by churning around some concoction of GOOPY, FOAMING, overly heavy trans/diff oils just so they can shift quicker??? What's the hurry, just pause a little longer and it will shift easily. 90 Wt or 140Wt gear oil does very well in a Model A.The heavier oils such as 600 W / steam-cylinder oil work better than SAE 140 or 90 for clash-free shifts - the gears stop spinning more quickly.
