Ok, talking about a '51 F-1 here. I'm just a carb away from being on the street with this truck and that carb is in the mail. So to get ready I thought i'd try to get it to crank. I charged up the battery but the prev. owner really hacked up the wiring harness all over the place. So I thought i'd eliminte as much as possible and start from there. It is a reverse polarity system with a positive ground.
So I hooked up the positive (ground) cable and hooked up the starter cable directly from the starter to the negative (hot) terminal, nothing happened. Shouldn't it have cranked?
When I stick a battery tester on the terminals it reads good, I can hook up either cable to the battery and it still reads as good, but when I hook up both cables it reads bad, suggestions?
