bobsmanstuff
I want to lift my 1930 pickup up and put it on jack stands. Is it safe to lift it up with a floor jack under the pumpkin? Thanks
And don't forget the "two redundant means of support" when working under a vehicle.
Mark "The Bird" Fidrych comes to mind.
Joe K
Simple thought. When using a jack - back it up with a "jack stand" or a second jack such that if the first jack should fail, the load is taken up by the second. The jack stand need not even carry any load initially - but "be there" in case of a failure.Please elaborate on "two redundant means of support", never heard that one before.
Having a single jack under four corners of a vehicle may not cut it by itself. Sometimes when one means of support fails, it cause other supports to be "out of line" or otherwise less than optimally applied and fail successively.
Joe K
Joe K, thanks.
Ditto
Hi Ayers
I have a motorcycle jack to pick up the front end under the axle and also works on the rear under the rear end.
It works perfectly!
31 pick up
31 coupe
I was a reporter for 17 years, and saw a lot of ugly carnage. One of the worst was the guy doing work beneath a double-wide trailer that had been using concrete blocks and no backup. Aaaagh!
Joe K
