Sorry team as you can imagine i have been busy with getting the machine to an operable state, fixing a few other of my cars and general things from life that get in the way.
YES its running , finally. The main problem was NOT timing at all as many focused on but a case of weak spark which a couple did. Since i don't mess with these every day i was not able to tell weak spark from healthy spark. This stemmed from using a stock flatty dizzy cap and not having the Pertronix wires reaching properly down into the cap hole but just enough to barely spark. Its quite distance in an unmatched setup. Once i figured a fix for this it went out all together and i found the lead wire inside of the dizzy touching the housing.
After all this i became fed up with the stock vacuum Loadamatic and the intake set up. So a bought an aftermarket two pot and two Stromberg rip offs with a Mallory Unilite mechanical advance and a Mallory coil. The Pertronix was deep sixed.
Running like a clock now just chasing the usual new build bugs at this point. I do appreciate all of the help i was given and all of the possible suggestions.
