Henry's Lady's Man
My starter brushes' wear are getting close to Les Andrew's recommended replacement. Two brushes are simply bolted to the starter's body (ground), but the two brushes on the ends of the field coils are soldered on. Now, I'm new at soldering, but I've tried a 70watt soldering iron and a thin butane soldering pencil. Neither has gotten this joint hot enough to melt the wire free, and you have to be careful not to burn thru the insulator strip that is against the body, or burn the insulation on the brush's wire.
A friend suggested that some things are copper-soldered and have to be cut off. What advice is out there for this?
(The brushes stick 5/16 beyond the holder; THE BOOK says they don't need replacing if at least 1/4 (4/16) is exposed below the holder. So, "technically", i may still be ok for a while. I don't think these brushes wear fast at all. They may be original. I bought the brushes as I am doing the bushings too.)
Bottom line, I still would like to get these new brushes in, while it's apart. Ideas and advice are welcome.
