tbirdtbird
It will surprise many here that the ethylene glycol component of antifreeze does in fact not oxidize or 'go bad'. This per an old chem prof of mine. I can supply the name of the prof and the university for the doubters. You can prove this to yourself by using your freeze protection tester every year , while not changing the ethylene glycol, and it will always test the same temp freezing point. What does oxidize, or 'go bad' are the antioxidants. If the antifreeze has a pH of 8, then the antioxidants are just fine. Once the pH hits 7, tho, time to replenish them separately by getting the small bottle off the shelf at the autoparts store. Armed with this information, I have not changed antifreeze, just added rust inhibitors, for more than 50 yrs, with no problems. This is important I think because the disposal of ethylene glycol presents such a problem
