Blip [on & off] the throttle with the clutch un touched. Before the transmission slows back down slip her from third into two, or from two into one with a slight finger pressure on the stick shift. It's very easy to do and there is no grind. You'll be suprised how fast this happens.
skip.
Skip, If I am understanding you correctly, there is no need to engage the clutch (double clutch) while downshifting from 3rd to 2nd as long as you blip the throttle to match gear/engine speeds?
Thanks,
Tim
