miwi
Hi,
I had rebuilt the transmission my own because the synchro blocker rings were heavily damaged. Since the rebuilding I drove around 1000 mi. I had sometimes the problem that I couldn't engage 1st or reverse gear when the car stands. I know it is unsynchronized and I double cllutching is the Thing shift unsyncho gears. My suggestion was that the clutch is the problem. But it was ok to drive it.
Yesterday I had the problem that my transmission was stucked in 3rd speed. I couldn't get the 3 speed out. I opened the box and the sleeve had over shifted. The pre synchro insert had tilt, so that the sleeve can't be moved back to neutral or 2nd Speed.
A closer look shows the following issues
Thanks for your help
Michael
- rear oil baffle worn and loose
- 0.05" -0.08" play of 2nd Speed and hub on mainshaft.
- 2nd speed trusth washer (between 2nd Speed and 1st speed) worn.
Michael
