Bud
What type snap ring pliers do you use on the retaining rings used in the V8 transmission? I used my cheap set with the replaceable pin ends, but it barely had enough travel to do the job and kept slipping off. I know about grinding the ends on the ring parallel and I did that. Is it better to use a snap ring pliers that has a parallel linkage? If so, what brand? If you have a picture of the pliers you use, that would be helpful.
Thanks
Thanks
