Atlantic28
Today, finished pulling all the bolts needed to pull the transmission from my 1929 closed cab pickup. Decided to pull the rear end out and drop the transmission that way (seemed easier than pulling the engine). Got the transmission backed out of the clutch splines, but transmission didn't have enough clearance to drop straight down.
The brake cross-shaft won't allow the u-joint housing to move back far enough to drop straight down. If I pull the front brake clevis pins, will the shaft rotate enough to give me the clearance I need? Or, would removing the universal joint be the way to go? Not much help in Les Andrews Mechanics Handbook, but looking for advice from someone that has endured the joy of dropping the transmission from a 1929. Thanks,
I wait with greasy hands!
Doug
Doug
