Transmission parts are installed as per installation schematic how ever I have two questions.
1) When I install the transmission rear main bearing and rear bearing retainer, the rear bearing moves back and forth within the confines of the bearing retainer about 1/4 of an inch. Using standard issue gasket that come in the kits. Wondering if gasket is too thick.
2) With the u joint not installed, what keeps the main output shaft from moving back and forth. The retainer ring inside keeps it from coming out the end but it still moves quite a bit inward towards the input shaft.
Hope this is written clear enough.
