jeepguy1948
I'm going to put a Mitchell transmission in my 28 RPU. I would like to get some feedback about stock ratio vs the 15% higher 1st & 2nd. I'm planning to get an overdrive from them a little farther down the road. Motor has high compression head,, Weber carb, header, fsi ignition, so it has more poop than a stocker. I do not know for sure what diff ratio I have either and with a closed driveline I don't know how to figure that out either. Being a truck it likely started out with a 4:10 but that could easily have been changed (my truck is actually going 40 miles an hour when the speedo says 35. Plus or minus a bit).Thanks
