Jim Johnston
A friend has been experiencing shifting problems he described as feeling like it was hung up between gears. Yesterday we removed the shift tower, and saw no abnormalities. Further investigation revealed that with the sliding gears in their neutral position the cluster cannot be rotated! We even tried turning it with a pry-bar with no success. If you put the sliding gear in to 1st gear and use the pry bar on the 1st - reverse slider you can make the cluster rotate, but it takes some effort. Likewise with the sliders in 2nd gear you can achieve cluster rotation by rocking the car back & forth, but again with considerable effort. The transmission has approx. 20K miles (stock engine, clutch, etc.). The owner is very diligent about keeping the transmission oil (600W) topped up. We are now going to remove the transmission, but was wondering if anyone has seen something similar and what they found. Forgot to mention that prior to this the transmission was not noisy. Thanks .
