S Sly Member Aug 31, 2015 #1 Hi, does anybody know the exact diameter of the top pin (which goes into the clutch) from the Main Drive gear - new part - (please see attached picture)? I need to check if my one is to much worn or not. Thanks in advance... stefan Attachments WP_20150829_009.jpg 33.3 KB · Views: 52
Mitch//pa BANNED Aug 31, 2015 #3 here is some addtl info http://fordbarn.com/forum/showthread.php?t=107193&highlight=Input+shaft
Bob/Kansas City Senior Member Sep 1, 2015 #5 The diameter of the end of the shaft where it goes into the pilot bearing should be .668". If there's more than about .001 or .002" of wear it should be replaced.
